led light does not work well after 2.2
This is a discussion on led light does not work well after 2.2 within the Nexus One forums, part of the Google Phones category; I've just updated to 2.2 but the led light does not seem to be working like it did before. It ist to flash when you ...
Thread: led light does not work well after 2.2
    Member mattwallis's Avatar
    I've just updated to 2.2 but the led light does not seem to be working like it did before. It ist to flash when you lock the phone doesn't anymore. I downloaded blink and when I got a call it flashed the colour once but then after was just white. And when I got a message nothing happened. I do have handcent installed I dunno if this effects it
    Any help much appretiated.
    Android Lurker maris's Avatar
    If you're using more than one program to set the trackball colors, go over your settings in each to be sure one isn't over-riding another. You probably have a conflict going somewhere.
    I just have blink mate.
    Member NPuter's Avatar
    Quote Originally Posted by mattwallis View Post
    You said in your original post that you have handcent too..
    You can only have one app trying to set the trackball for a notification or you will run into problems...
    And, at least for me, the trackball does flash when I put the phone to sleep (of course only when there is an active notification...)
    I've got it working now. I'm liking the colours
nexus+10+notification+light+not+coming on
