32gb Micro SD problems with Nexus One
This is a discussion on 32gb Micro SD problems with Nexus One within the Nexus One forums, part of the Google Phones category; my N1 has a 32GB SD card but it only shows 9All The Time) 29gb no matter how much is on there , any explanations?...
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 32gb Micro SD problems with Nexus One
  1. #21
    Junior Member gw0gvq's Avatar
    32gb sd
  2. #22
    Quote Originally Posted by gw0gvq View Post
    It's probably due to the difference between what a GB and Gb mean. There are different ways that it's measured https://secure.wikimedia.org/wikipedia/en/wiki/Gigabyte
    There is also some formatting overhead that takes some space.
  3. #23
    Junior Member talcott's Avatar
    A gigabit is a unit of measurement used in computers, equal to one billion bits of data. A bit is the smallest unit of data. It takes eight bits to form or store a single character of text. These 8-bit units are known as bytes. Hence, the difference between a gigabit and a gigabyte is that the latter is 8x greater, or eight billion bits.
  4. #24
    Junior Member kelvin188's Avatar
    Kingston 32gb
    Quote Originally Posted by jdallac View Post
    I bought a 32gb micro SD off ebay for about $40. When it first arrived, I plugged it into my laptop via USB adaptor and it showed 32gb of storage.
    I put it into the Nexus One and it only showed up as 8gb. I formatted it with the Nexus One, hoping this would fix it but no...it said 8gb after the format.
    So I put it back into my PC to format it back to 32gb and...It seems to be stuck at 8gb. It will not reformat to 32gb (won't even show an option to go higher than 8gb) I've tried windows 7, xp, vista...all the same thing. They now see it (and will only format it) as an 8gb card.
    Anyone have any ideas? I have tried at least 3 programs off the internet, all specifically for formatting high capacity micro sd cards, but after the Nexus One formatted it to 8gb...it seems stuck at 8gb!
    I bought a Kingston Class 4 for my wife's Tmobile touchscreen phone. She has been using it to take video, pictures for her phone. It shows 32gb on both my PC, Netbook, and cell phone . I got mine here:
    SOLAR TORRENT
    Hope this helps.
    Kelvin
32gb android sd card only shows 29gb
32gb micro sd card only showing 29gb
32gb mini sd card formatted to way less
32gb sandisk to android 29gb
32gb sd card shows only 29 gb
36gb microsd only showed 29gb on phone
android 32gb card only 29 accessable
google nexus problems bootleg
micro sd into nexus
nexus one mini sd
only 29gb available on 32gb micro sd card
only 29gb of 32gb available micro sd
phone shows 29gb on 32gb card
requirements for 32gb sd on android
why does my 32gb micro sd card only hold 23.9gb
