Please help me with a hardware reset
This is a discussion on Please help me with a hardware reset within the Nexus One forums, part of the Google Phones category; My phone was getting slow, so I decided to do a hard reset. I wanted a clean and new phone. Unfortunately, after the reset the ...
Thread: Please help me with a hardware reset
    Senior Member elvis1's Avatar
    Unfortunately, after the reset the phone re-downloaded all my apps, remembered my settings and so on. I know this is a smart-phone, but does it have to be THAT smart?! I don't want all these apps back.. I want it cleeeeaaan!!
    Anyway to do this?
    Thanks!
    Senior Member NexusDro's Avatar
    After you factory reset the phone, it will ask you if you want to restore your backup data, just uncheck that box.
    hmmm... it did actually not ask me that question. It asked me if I wanted to sign in to my google account..
    hmm
    Or try this: Go to Settings -> Privacy, uncheck "Back up my data". Then do a hard reset.
hardware reset me
