NX1 Battery
This is a discussion on NX1 Battery within the Nexus One forums, part of the Google Phones category; Hi guys, I just bought my NX1 yesterday and I directly exploring the device. I just noticed after some time that (according to the user ...
Thread: NX1 Battery
    Junior Member 7od1's Avatar
    NX1 Battery
    Hi guys,
    I just bought my NX1 yesterday and I directly exploring the device. I just noticed after some time that (according to the user guide) I should charge it until full before use.
    Will it make any problem to the battery if I did it that way (the battery power was left only a forth when I charged it for first time) ?
    Senior Member antikryst's Avatar
    Don't worry about it. I side the same thing and my battery is fine. Just couldn't wait so I just charged it a bit then I played away.
    Senior Member coldfusionb's Avatar
    I also did the same thing and mine still works fine.
    One Nexus To Rule Them All!
nx1 battery
