Snesoid / Genasoid Wii mote problem
This is a discussion on Snesoid / Genasoid Wii mote problem within the Nexus One forums, part of the Google Phones category; hi i cant seem to get the wii mote to work with snesoid ive got the wii mote app from market and my wii mote ...
Thread: Snesoid / Genasoid Wii mote problem
    Member mattwallis's Avatar
    hi i cant seem to get the wii mote to work with snesoid ive got the wii mote app from market and my wii mote is connected fine.do i have to set up anything. i have been in the snesoid menu and ticked the box that lets other control s control the game but nothing.....
    any help would be much appretiated, cheers.
    Senior Member eZdoesit's Avatar
    I'm haveing the same issues.
    Junior Member Tails86's Avatar
    Under settings, go to "Other Settings." Check the "Use input method" checkbox. After that, map the proper keys under the input settings and you should be good to go.
