will handset ring w/ headset connected?
This is a discussion on will handset ring w/ headset connected? within the Nexus One forums, part of the Google Phones category; Hi, My handset used to ring with the headset connected. After installing CM RC3 the headset would ring but not the handset. Am I missing ...
Thread: will handset ring w/ headset connected?
    Junior Member topcat_nexusone's Avatar
    Hi,
    My handset used to ring with the headset connected. After installing CM RC3 the headset would ring but not the handset. Am I missing some configuration here with RC3? Need handset to ring coz I don't have the headset plugged in my ear always Thanks!
    up.. no one having the same problem? tried bluetooth today instead on the wired headset still no ring. deleted most of my apps still no ring. am missing a bunch of calls coz n1 not ringing
    I don't know if you are using any nightlies, but the one i have, under cyanogen settings, there's an to adjust notifications and sound while a head set is used.
    Come here little sheep; I have a nice juicy apple for you!
    [SIGPIC][/SIGPIC]
    Nexus One: Locked and Rooted
    ROM: CM7
    Quote Originally Posted by iPhoneSlayer View Post
    thanks for the reply iphoneslayer.. sorry for the ignorance but whats a nightlies? am using cyanogen rc3.. i got application settings, input settings, performance settings and user interface under cyanogen menu. nothing in it relates to headset notification.. i feel like am missing something here.. how can n1 not ring w/ the headset on.. odd
    Nightlies are incremental builds on cyanogen RC3. RC3 means Release Candidate 3. Then everynight there are addons and bug fixes called nightlies
    More info here [NIGHTLY] [ROM] [FRF91] CyanogenMod 6 for vendor passion (HTC Nexus One) - xda-developers
    You might have it under a different location.
    Try settings>sound
    [SIGPIC][/SIGPIC]
    ROM: CM7
    thanks iPhoneslayer! will update to the nightlys and hopefully it will solve my no ring problem!
android cm no ringtone with phones plugged
cyanogenmod 7 headset no ringing x8
