Help
This is a discussion on Help within the Nexus One forums, part of the Google Phones category; I got this phone from a friend. I started deleting icons and I deleted the android icon. Is it necessary to have it and how ...
Thread: Help
    Junior Member Lonewolf123654's Avatar
    Help
    I got this phone from a friend. I started deleting icons and I deleted the android icon. Is it necessary to have it and how do I get it back on my phone
    14 times
    Android Icon? Not sure I know what you mean. You deleted an app with an android logo for the icon?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Feb 2012
    10 times
    If you're talking about the tips icon, it's a widget. Long press anywhere on the screen to bring up the menu.
    Androidfied.
    You've probably deleted the icon from your homescreen only..
    got to the App Drawer (Bottom Centre looks like pack of squares) click on that
    you will find all the icons you need...
    click and hold the one you want and it will go back to your homescreen
    Cheers
