Battery Myths Busted: 5 Myths About Increasing and Decreasing Android’s Battery Life
This is a discussion on Battery Myths Busted: 5 Myths About Increasing and Decreasing Android’s Battery Life within the Nexus One forums, part of the Google Phones category; Saw this article regarding battery life myths on WCCFTech.com by Waisybabu Busted: 5 Myths About Increasing and Decreasing Android's Battery Life Here is what really ...
Results 1 to 10 of 19
Thread: Battery Myths Busted: 5 Myths About Increasing and Decreasing Android’s Battery Life
    Senior Member nickshertzer's Avatar
    Here is what really caught my eye:
    “To also help with Battery Life you can do these steps exactly:
    Turn your device ON and Charge the device for 8 hours or more
    Unplug the device and Turn the phone OFF and charge for 1 hour
    Unplug the device Turn ON wait 2 minutes and Turn OFF and charge for another hour.
    Your battery life should almost double, we have tested this on our devices and other agents have seen a major difference as well”
    Source:
    Official response from HTC RE: How to double battery Life (WORKS!) + 2nd Reply - xda-developers
    Member svenner's Avatar
    Very Interesting. Think I'll try it out and post back.
    Let us know how it works out. I'm curious and would love to try it but my phone is work and it'd be the weekend before I can try it.
    Yes, will do. I assume by On and Off they mean screen and not a full shutdown and power up?
    No, I understood it to be turning it off by the power button. That is why I am thinking it would be the weekend before I could try it.
    jah
    jah is offline
    Senior Member jah's Avatar
    Sounds like you have to do this almost every time to get real benefits from it, but a lot of people are saying it works.
    I wonder, though, how much life this takes out of your battery. It sounds almost like battery overclocking.
    Senior Member Nobby's Avatar
    I do NOT Recommend this, i have tried this and yes it has its benefits BUT it also changes the Battery Cache for the worse. Because of this i lost 2% battery over 12 hours (sleeping time) and had on the phone both HSDPA & Sync enabled all night, now i would say this was pretty good however when the phone finally drained to 10% it shut down with an apparent 10% charge and would not power past recovery. to fix this i had to clear the battery Cache but i also lost the progress i made and the following night in the same position lost 12% over 12 hours.
    NEXUS ONE
    11.02.2010 - SuperBoot Rooted
    NOTION INK ADAM
    02.05.2011 - BEAST 2.2
    Good feedback Nobby! Thank you for the reply as I'm not going to be doing that now.
    It is a good idea but could damage the phone, i followed the guide to the letter and found that 10% was the cut off point but extensive "battery tuning" may result in a larger "dead zone"
    NEXUS ONE
    NOTION INK ADAM
    well, no mucking around for me then. thanks for the heads up!
5 myths about increasing and decreasing android's battery life
android battery cache clear
android battery life myths
android battery myths
battery myths android
myths about tablet battery
myths for improving battery life
phone battery life decreasing
tablet battry myths
