Help: My N1 full with water
This is a discussion on Help: My N1 full with water within the Nexus One forums, part of the Google Phones category; I'm using N1 since 3 months , unfortunately it submersed in water , i took out the battery & dray the phone , try to ...
Results 1 to 10 of 15
Thread: Help: My N1 full with water
    Junior Member seaman's Avatar
    Thumbs up Help: My N1 full with water
    I'm using N1 since 3 months , unfortunately it submersed in water , i took out the battery & dray the phone , try to restart but it shows black screen with red , green color in the scroll ball.
    Any advice to back my N1 in service?
    Unhappy
    I pray with you for your N1
    Senior Member coldfusionb's Avatar
    Let it set in a bag of rice for 24hr with out the battery. Then try again.
    One Nexus To Rule Them All!
    Quote Originally Posted by coldfusionb View Post
    Let it sit in a bag of rice for 24hr with out the battery. Then try again.
    Bag of UNCOOKED Rice!
    THANK YOU coldfusionb
    Senior Member f0ul99's Avatar
    I maybe have read it somewhere about Nexus One giving colorful warning light when it detected moisture. The good news is that guy send it to HTC and it's all fine afterwards. In your case, full dip in water, going to HTC is the best bet.
    P/s: When I read this, I was sitting on the toilet bowl! Well I am sure that'll be my last. :D
    InViSiBLe-cHoKe by TaPaTaLk
    Quote Originally Posted by f0ul99 View Post
    +1 on the toilet bowl !!!!
    NOW what will i fiddle with ??
    Member AspiringDeveloper's Avatar
    My daughter's Samsung MP3 player went throught the washing machine and dryer. With nothing to lose we opened it up and left it on a shelf for a week. I was flabbergasted to find it worked. Never just assume it's impossible.
    Nexus One :nexusx: FINALY rooted without ending up like this
    Got CM7 installed too!
    No problem hope it helps.
    Junior Member club968's Avatar
    The N1 is not to be used as a flotation device
    Senior Member Larry_nexusone's Avatar
    I've baptized a couple phones. They survive if they are off, if on - not so good. Turning on immediately - bad. Opening up to allow air dry before turning on a must. In a bag of rice very good, will draw water and moisture out.
    Would be a decent idea to have an automatic shut down in presence of moisture engineered in these devices. It seems it's a fairly frequent electronic demise to dunk these things.
    :nexusx: Serious Android Fan :nexusx:
    Don't see anything in a newer phone that gives me a temptation to leave my Nexus One!
