Help
This is a discussion on Help within the Nexus One forums, part of the Google Phones category; I am currently running a hacked version of nexus one froyo 2.2 and after I attempted to partition the sd card my sd card does ...
Thread: Help
    Junior Member Nexusoneforum's Avatar
    Help
    I am currently running a hacked version of nexus one froyo 2.2 and after I attempted to partition the sd card my sd card does not show up anywhere it says its not present. I have my sd card put in and i don't know what I did and I want to fix it. Pleaaase Help
    First off welcome to the forum
    Second by hack do you mean stock froyo with root access or a custom ROM? If itís the custom ROM then try flashing a stock one if you made a nandroid then you can use that. If not no big deal just look around on this forum or over at the xda forum and you should be able to find one. At least that would be the first thing I would try.
    did you mount phone thru usb to see sd card on pc or try mini partition tool from web.
    If you don't unmount correctly you can wipe card.
    What recovery did you use to partition and the steps you took.
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    The problem is that my usb is not picking up any memory card at all from my phone. I want to reset the partitioning so I can unroot my phone because the root is ruining my phone (can't pick up usb,no wifi, no signal, restarts frequently) I looked everywhere no one seems to have any problem like me. I am not running any custom rom
    Quote Originally Posted by rugmankc View Post
    I was following steps to install htc sense ui alpha 19 and i blindly tried the partitoning. I hit the first two numbers that popped up. I want to be able to see my sd card. It would be aapreciated if you can help. Thanks for the reply....
