Where are my ringtones?
This is a discussion on Where are my ringtones? within the Nexus One forums, part of the Google Phones category; Hey guys, I've been using Ringdroid to make custom tones, and I recently deleted one from Astro file manager, and when I go to select ...
Thread: Where are my ringtones?
    Member damien8's Avatar
    Hey guys,
    I've been using Ringdroid to make custom tones, and I recently deleted one from Astro file manager, and when I go to select my Phone ringtones, it still shows up in the list. Of course, since the file is deleted, when I try to select it, it doesn't play any sound.
    Can someone tell me how I can go about deleting that tone from my list, and also, where does Android keep these files?
    Thanks in advance
    I don't think you can. Had same problem and had to wait till I changed roms. I use an app called ringtone and it lists all my songs and lets me trim them. It will allow for deletion.
    I did find something under system/media/audio/ringtones that lists what appears to be the phones ringtones and longpressing allows for deletion.
    I would think what ever program you used to make the ringtone would allow for deletion.
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    try downloading "rings extended". have been using since the release of the g1. they go great together
    Senior Member Larry_nexusone's Avatar
    Ringtones, Nope, I didn't take them.
    :nexusx: Serious Android Fan :nexusx:
    Don't see anything in a newer phone that gives me a temptation to leave my Nexus One!
ringtones deleted on nexus 1
where are my ringtones in a lgt385
