Power Button not working
This is a discussion on Power Button not working within the Nexus One forums, part of the Google Phones category; Has anyone else had the power button fail on them? Is there another way to turn on my nexus one? The power button has slowly ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Power Button not working
    Junior Member Bronto's Avatar
    Is there another way to turn on my nexus one? The power button has slowly gotten worse and worse, and I cant get my phone to turn on now...
    There's quite a few with the same prob...
    To turn on, plug in the charger, then remove and reinstall the battery.
    Junior Member cachiama's Avatar
    Just send it to HTC, they will repair it for free. Speaking from experience
    danger-rat. that is supposed to make the phone auto boot? Cause mine doesnt seem to...
    Should make it power on...
    Not working?
    It just turns on the Charging red light.
    Doesnt boot the phone. Anything else I can do?? I know the phone is working its just the power button...
    Does the battery have to be full for it to boot the phone?
    Not sure, I've done it before in the past, but I'm struggling to do it myself right now...
    Anyone else able to do that?
    Is there any other way to turn on without using power button?
    THANK YOU maurobj!!!!!!!!!! Your Awesome
    This worked for me!
    "It will happen sooner or later, you will have to start your Nexus One after the battery will have died or after changing the SIM or SD-card. Without the power button, it would seem impossible, but you can! The trick is to connect the phone via USB to a power source (a charger or computer) and then to remove and insert the battery successively, after a while (5-10 insertions) the device will get confuse and will start."
    wooooooo!!
android power button not working
android wx435 power button not working
another way to turn on a asus nexus
how to jump the power butoon on chromo tablet
htc google nexus one power button ways
htc nexus one power button jumper
htc nexus one power button not working
htc nexus one power button ways
htc one power button not working
nexus 7 power button not responding
nexus 7 power button not working
power button not working on android phone
the power button of my android is not working
what happens when an android tablet doesn't wake up and the charger is not working
