Phone wont connect to wireless
This is a discussion on Phone wont connect to wireless within the Nexus One forums, part of the Google Phones category; I just setup wirless at my place of buisness and the laptop connects fine but for my nexus it wont let me. It keeps saying ...
Results 1 to 10 of 10
Thread: Phone wont connect to wireless
    I just setup wirless at my place of buisness and the laptop connects fine but for my nexus it wont let me. It keeps saying obtaining ip address, then never connects.
    are you running stock ROM?
    Ne:nexusx:uS One ROOTED
    Cyanogen Mod Nightly ROM
    Quote Originally Posted by baseballfanz View Post
    Yes i am. I just got home and connected to my home wireless just fine but not the one at my job. weird. I have 2 computers hooked up wireless at work and they work fine. i just get stuck with an obtaining ip address and then saying searching for network.
    My guess it’s the router at your business it is not so great for android. I think there is an app called wifinder that is suppose to help this or according to this thread http://www.nexusoneforum.net/forum/v...on%60t+connect
    Member insomnium's Avatar
    i had the same problem with dd-wrt , but forget how i fixed it
    its some router option i had to change..maybe i'll remember after some sleep...
    problem occured after i rebooted the router...
    only option i see different from my normal is that ssid broadcast is now enabled...
    Well the same router i have at work is the same router i have at home which makes it even more weird.
    is it setup the same way as the one from work?
    If all else failed, a factory reset would probably be a good idea to see if it
    will fix it.
    will fix it.
    I`m not really sure that will solve anything this doesnít sound like itís the phone it sound more like itís the router. But you never know right.
    I dont know if its setup the exact same way. Also i would rather just not use wifi at work instead of hard resetting. Ill test out some other cell phones.
android phone wont show my internet adress
my android phone is connected to my wireless network but it wont let me on the internet
nexusone will not connect to wireless
