disconnect N1 battery charging while tethered to laptop?
This is a discussion on disconnect N1 battery charging while tethered to laptop? within the Nexus One forums, part of the Google Phones category; Hey All, I tethered my nexus one to my battery-charged laptop today and my N1, which started to charge off my laptop's battery, began to ...
Results 1 to 10 of 11
Thread: disconnect N1 battery charging while tethered to laptop?
    Member junkeeroo's Avatar
    Hey All,
    I tethered my nexus one to my battery-charged laptop today and my N1, which started to charge off my laptop's battery, began to drain my laptop's battery in record speed. Is there any way to stop charging the N1's battery when you're tethered up?
    Thanks!
    14 times
    Quote Originally Posted by junkeeroo View Post
    Hey All,
    Thanks!
    Why not use Wireless Tether?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    dang...that was a simple solution. thanks.
    another newb question, which uses more battery: 3G or wifi? thanks again.
    key
    key is offline
    Member key's Avatar
    Yea i actually wanna know that too, on the N1 which uses more battery wifi or 3G?
    14 times
    In my personal experience, 3G uses more battery than Wifi.
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    key
    key is offline
    Member key's Avatar
    Oh, my N1 Drains battery crazily on WIFI. Is there an extended battery which is the exact same size as the stock one?
    14 times
    Check this out
    seidioonline.com
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Android Lurker iPeck's Avatar
    Laval, Qc
    I'm experiencing more battery drain from wifi than 3g thats for sure
    14 times
    Either of you have Rooted phones?
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Senior Member Nobby's Avatar
    I have found that i can get several days (3-4) on a wifi enabled, 3G disabled run like when i am away or out of the country. however i can barely get 2 days out of my current build running on 3G alone.
    NEXUS ONE
    11.02.2010 - SuperBoot Rooted
    NOTION INK ADAM
    02.05.2011 - BEAST 2.2
