3G or wifi drain more battery?
This is a discussion on 3G or wifi drain more battery? within the Nexus One forums, part of the Google Phones category; What's your experience? And if you rooted your phone, did it change battery drainage using either or? Cheers....
Results 1 to 8 of 8
Thread: 3G or wifi drain more battery?
    Member junkeeroo's Avatar
    Quote Originally Posted by junkeeroo View Post
    Yes they both drain more. When I'm not goin to be using internet or downloading anything I switch to 2g. It makes a huge difference. I've been told rooting makes a huge difference and that there are apps that help with rooted phones even more.
    Well between 3G and WiFi, 3G will drain more battery than WiFi.
    Ne:nexusx:uS One ROOTED
    Cyanogen Mod Nightly ROM
    Junior Member RodMyers's Avatar
    Quote Originally Posted by baseballfanz View Post
    I found this to be true as well.
    But not by near as large of a margin as the difference between wifi and 2g.
    Junior Member gregory9's Avatar
    I'm new to the whole smartphone experience; if I select "Use only 2G," how does that limit the phone's functionality? In other words, what can't I do using 2G that I could do by allowing 3G?
    Thanks.
    Android Jr Member gonzo13's Avatar
    you can do, basically, everything you could do on 3G, just infinitely slower.
    you can't browse the web while on a call in 2G only, if i'm not mistaken.
    Subscribe to the Droidforum RSS feed!
    No multitasking on 2G, also if your'e on the web our anything with 2G all your phone calls get routed straight top voice mail.:D
3g drain more batteri than 2g
android battery drain only with 3g
drain battery wifi and 3g
nexus 7 3g battery drain
what drains more cellphone battery wifi or 3g?
wifi or 3g drains battery android
