CyanMod Problem/question
This is a discussion on CyanMod Problem/question within the Nexus One forums, part of the Google Phones category; I have now twice tried to delete n app from the home screen and out of habit dragged it down to where the trash can ...
Thread: CyanMod Problem/question
    I have now twice tried to delete n app from the home screen and out of habit dragged it down to where the trash can appears on Android. The trash can is up top on Cyanagen.
    Unfortunately an app when dragged to the app drawer location REPLACES the app drawer and you can no longer retrieve your apps...other than using the search widget.
    How do I remedy this problem short of reinstalling CyanagenMod?
    Ya Know. I just needed to play around with it.
    Long press desktop>Custom shortcut>Pick your activity>Open/Launcher Actions>Close App Draw>OK and then drag it to where the app drawer was before and it's back!
    14 times
    Thats ADW thats changing the Trash Can icon location to the top.
    Please try to post questions about CM in the appropriate thread instead of starting new ones. Thanks!
    http://www.nexusoneforum.net/forum/n...1-problem.html
    http://www.nexusoneforum.net/forum/n.../8783-cm6.html
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
cyanamod 7 google market download problem
