Nexus One and car head unit
This is a discussion on Nexus One and car head unit within the Nexus One forums, part of the Google Phones category; Originally Posted by Tapage I have a pioneer stereeo unid and was a bit scary to connect my nexus one to it throught usb .. ...
Results 21 to 30 of 43
Thread: Nexus One and car head unit
  1. #21
    Senior Member bourne's Avatar
    Quote Originally Posted by Tapage View Post
    I have a pioneer stereeo unid and was a bit scary to connect my nexus one to it throught usb .. I already try the bluetooth option but that invalid my bluetooth phone option .. which I prefeer more ..
    I would do it and report it back here ..
    cool man do it up and let us know how it goes!
    .:. phoneStats .:.
    .:. Nexus One
    .:. version 2.3.4
    .:. build number GRJ22
    .:. ROOT - Stock Gingerbread img
    .:. Update from Gingerbread 2.3.3 to 2.3.4 and maintain root
  2. #22
    Member Tapage's Avatar
    Well I did my homework ..
    here my car unit ..
    1. when conected to the car unit it ask to turn on the mas storage mode
    2. if you turn on it start reading format .. locate tracks but nothing else
    3. it charge the phone ..
    4. you still can recieve and make calls
    5. you can play music through music player, but sounds it's on the phone speaker
    6. Did not test further
    N1 CM7 nightly
  3. #23
    here my car unit ..
    N1 CM7 nightly
  4. #24
    You also need to select the mount option on your phone
    here my car unit ..
    N1 CM7 nightly
  5. #25
    Quote Originally Posted by johnny cizzle View Post
    sure I did .. which it's a bit anoying coz if I actuvate the usb option on the phone and the car unit wasn't ready it wont catch it ..
  6. #26
    That's really strange. I guess it's because those things are designed to be used with istuff.
  7. #27
    I have the AVH-4000 in both my vehicles, and I believe the USB hook up has to be WinMedia compatible, or something like that...
    I'll check the manual when I get home...
  8. #28
    I used to use this one with my iphone and was working flawless .. anycase I place all my music in a usb stick and problem solved ..
  9. #29
    Feb 2012
    10 times
    I use bluetooth and use the Equalizers on PowerAmp or MixZing Apps to balance the frequencies out. It's sounds top notch for me. I love it. No wires in the way other than the charger and can use my phone as the "remote" for the music. I like PowerAmp cause I just swipe from songs or albums.
    Androidfied.
  10. #30
    Do you have USB debugging on
golf nexus head unit
