Gingerbread does not work well on my N1
This is a discussion on Gingerbread does not work well on my N1 within the Nexus One forums, part of the Google Phones category; I have downloaded and installed Ginerbread. Not only did it not improve anything, it broke some applications including just the phone. Volume of incoming calls ...
Thread: Gingerbread does not work well on my N1
    Junior Member Lanny's Avatar
    I have downloaded and installed Ginerbread. Not only did it not improve anything, it broke some applications including just the phone. Volume of incoming calls is about half and the other party has hard time hearing me. I am going back to Froyo.
    Junior Member ren2008's Avatar
    Ah poor you.... Gingerbread is awesome! i would first try it again BUT with a factory reset before installing GB and then do the upgrade.
    if it fails, stick with Froyo! good luck
    I appreciate you sympathy and advice. I would be prepared to do that if there was a clear indication that it will do anything useful (the reset, that is).
    well a reset will clear everything stored in the phone memory including the commands and cache that messed up your GB installation. in fact, a soft reset was recommended before installing the new ROM.
    Your SD content won't be affected, so all you have to do is backup your contacts and app list.
    software reset does anything but good to an old phone, it will revice it. that is of course if your problem is not hardware related.
    Junior Member fallacy's Avatar
    were you 100% stock before? That's why I wait for the OTA. Sometimes those downloads don't go well.
    Quote Originally Posted by fallacy View Post
    Yes, I was.
    Apart from the problems described, my fonts and screen seem odd.
