Need Help!!!!!!!!!!!!!!
This is a discussion on Need Help!!!!!!!!!!!!!! within the Nexus One forums, part of the Google Phones category; It says E: Error in /sdcard/update.zip (status 7) installation aborted...
Results 11 to 20 of 29
Thread: Need Help!!!!!!!!!!!!!!
    Member ptclik85's Avatar
    Where are you getting your file from?
    I cant remember, if you have the link could you send it to me
    I'm just uploading a file for you right now...
    Ok much appreciated
    Here ya go...
    http://db.tt/aq6NvJ0
    MD5:
    706a4631271b6ee2c819ab548394b71e
    Its still doing the same thing. I have no clue what to do
    If you have superuser on the phone, does that mean it's rooted?
    Quote Originally Posted by ptclik85 View Post
    Yes!
    You may also have a custom ROM, so installing the update may be a bad idea...
    How come you're rooted but have a stock recovery?
    Download ROM Manager and install clockwork 2.5.1.4 from the All Clockwork Recoveries option at the bottom of the menu...
    I have no idea because I can't use any rooted apps so I don't know how it's rooted but not rooted at the same time. I also don't have the unlocked symbol when my phone boots up. I thought that if you had the unlocked symbol you were rooted.
