Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
This is a discussion on Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!! within the Nexus One forums, part of the Google Phones category; I tried that and it still didn't work Sent from my HTC Glacier using Tapatalk...
Results 11 to 20 of 43
Thread: Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
    Member ptclik85's Avatar
    Is your recovery text orange?
    Sent from my NookColor using Tapatalk
    Yea orange and black
    You're using the 3.x version of Clockworkmod recovery, and that may be the problem. Have you ever used adb or fastboot?
    Yea I'm using that version and yes I've used adb
    In that case, I would download a copy of flash_image, and also clockwork 2.5.1.4, and use "adb flash_image recovery recovery.img" to install the older clockwork recovery (where recovery.img is the name of your downloaded recovery).
    I think you'll have more luck with the older clockwork...
    How do I go about doing that
    Download this, and place it in your sdk tools folder
    http://db.tt/dzEHdJS
    Do the same with this...
    http://db.tt/BgeHZqJ
    Ok I did that what's next?
nexus one stuck on hboot
