Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
This is a discussion on Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!! within the Nexus One forums, part of the Google Phones category; Connect your phone to the PC, and confirm connection (type "adb devices", if it responds with a device number, you're connected). Once connected, type "adb ...
Results 21 to 30 of 43
Thread: Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
  1. #21
    Once connected, type "adb flash_image recovery clock.img"
    This will install the older clockwork recovery, and you will need to type "adb reboot recovery" to use it...
    Sent from my NookColor using Tapatalk
  2. #22
    Member ptclik85's Avatar
    I tried but when I typed that in its not showing my device. Do it needs to be with fastboot?
    Sent from my HTC Glacier using Tapatalk
  3. #23
    No, you need to be booted past bootloader enough the the daemon is running. Recovery should be enough...
    Booting into the fastboot screen and confirming fastboot connection, then booting into recovery sometimes helps though...
  4. #24
    Ok I did that, what's next?
  5. #25
    You got a new recovery, with green text?
    If so, do a complete wipe, including system, then try and reinstall your ROM...
  6. #26
    No it didn't give me a new recovery
  7. #27
    Its still on rom manager
  8. #28
    ROM Manager is a front end interface that runs as an app.
    The orange text is Clockwork 3.x recovery, not ROM Manager...
    What response did you get from adb when you typed "adb flash_image recovery clock.img"?
  9. #29
    It showed a whole bunch of writing then after that I typed in the last command that rebooted the phone back into the orange writing again
  10. #30
    Can you cut and paste the writing, so I can see it?
nexus one stuck on hboot
