Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
This is a discussion on Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!! within the Nexus One forums, part of the Google Phones category; It won't let me copy the writing the command Sent from my HTC Glacier using Tapatalk...
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
  1. #31
    Member ptclik85's Avatar
  2. #32
    It will...
    Right click on the bar at the too of the window, select edit, then select all, then right click on the bar again, select edit, then copy...
    Sent from my NookColor using Tapatalk
  3. #33
    Microsoft Windows [Version 6.1.7600]
    Copyright (c) 2009 Microsoft Corporation. All rights reserved.
    C:\Users\Jason\Desktop\SDK\tools>adb devices
    List of devices attached
    HT9CYP808149 recovery
    C:\Users\Jason\Desktop\SDK\tools>adb flash_image recovery clock.img
    Android Debug Bridge version 1.0.26
    -d - directs command to the only connected USB devic
    e
    returns an error if more than one USB device is
    present.
    -e - directs command to the only running emulator.
    returns an error if more than one emulator is r
    unning.
    -s - directs command to the USB device or emulator w
    ith
    the given serial number. Overrides ANDROID_SERI
    AL
    environment variable.
    -p - simple product name like 'sooner', or
    a relative/absolute path to a product
    out directory like 'out/target/product/sooner'.
    If -p is not specified, the ANDROID_PRODUCT_OUT
    environment variable is used, which must
    be an absolute path.
    devices - list all connected devices
    connect [:] - connect to a device via TCP/IP
    Port 5555 is used by default if no port number
    is specified.
    disconnect [[:]] - disconnect from a TCP/IP device.
    is specified.
    Using this ocmmand with no additional arguments
    will disconnect from all connected TCP/IP devic
    es.
    device commands:
    adb push - copy file/dir to device
    adb pull [] - copy file/dir from device
    adb sync [ ] - copy host->device only if changed
    (-l means list but don't copy)
    (see 'adb help all')
    adb shell - run remote shell interactively
    adb shell - run remote shell command
    adb emu - run emulator console command
    adb logcat [ ] - View device log
    adb forward - forward socket connections
    forward specs are one of:
    tcp:
    localabstract:
    localreserved:
    localfilesystem:
    dev:
    jdwp: (remote only)
    adb jdwp - list PIDs of processes hosting a JDWP transport
    adb install [-l] [-r] [-s] - push this package file to the device and i
    nstall it
    ('-l' means forward-lock the app)
    ('-r' means reinstall the app, keeping its data
    ('-s' means install on SD card instead of inter
    nal storage)
    adb uninstall [-k] - remove this app package from the device
    ('-k' means keep the data and cache directories
    adb bugreport - return all information from the device
    that should be included in a bug report.
    adb help - show this help message
    adb version - show version num
    DATAOPTS:
    (no option) - don't touch the data partition
    -w - wipe the data partition
    -d - flash the data partition
    scripting:
    adb wait-for-device - block until device is online
    adb start-server - ensure that there is a server running
    adb kill-server - kill the server if it is running
    adb get-state - prints: offline | bootloader | device
    adb get-serialno - prints:
    adb status-window - continuously print device status for a specifie
    d device
    adb remount - remounts the /system partition on the device re
    ad-write
    adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
    tloader or recovery program
    adb reboot-bootloader - reboots the device into the bootloader
    adb root - restarts the adbd daemon with root permissions
    adb usb - restarts the adbd daemon listening on USB
    adb tcpip - restarts the adbd daemon listening on TCP on th
    e specified port
    networking:
    adb ppp [parameters] - Run PPP over USB.
    Note: you should not automatically start a PPP connection.
    refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
    [parameters] - Eg. defaultroute debug dump local notty usepeerdns
    adb sync notes: adb sync [ ]
    can be interpreted in several ways:
    - If is not specified, both /system and /data partitions will be u
    pdated.
    - If it is "system" or "data", only the corresponding partition
    is updated.
    environmental variables:
    ADB_TRACE - Print debug information. A comma separated list
    of the following values
    1 or all, adb, sockets, packets, rwx, usb, sync
    , sysdeps, transport, jdwp
    ANDROID_SERIAL - The serial number to connect to. -s takes prior
    ity over this if given.
    ANDROID_LOG_TAGS - When used with the logcat option, only these de
    bug tags are printed.
    C:\Users\Jason\Desktop\SDK\tools>adb reboot recovery
  4. #34
    Don't worry about the last 3 lines I hit enter after the phone rebooted
  5. #35
    No worries...
    We're gonna try a different approach.
    Follow this guide to Unroot/restore your N1, using the passimg method with the FRG33 image.
    Nexus One/Guides & Tutorials - XDA-Developers
    We can re-root your phone afterwards...
  6. #36
    Will I have to change my hboot?
  7. #37
    Nope.
    This will either work, or it won't.
    Hboot won't make a difference...
  8. #38
    It worked so unrooted right now, right?
  9. #39
    So I'm on EPE76, which saying I'm running on 2.1, will I need to upgrade to another build to root my phone?
  10. #40
    Just root, using this:
    http://www.nexusoneforum.net/forum/n...e-windows.html
nexus one stuck on hboot
