Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
This is a discussion on Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!! within the Nexus One forums, part of the Google Phones category; I followed the guidelines to put this rom on the phone but as soon as I did of course the rom didnt work, but then ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Nexus One Stuck In Hboot SOMEONE PLEASE HELP!!!!!!!!!!!!!!!!!
    Member ptclik85's Avatar
    I followed the guidelines to put this rom on the phone but as soon as I did of course the rom didnt work, but then I put my backup rom on there and it installed correctly but as soon as I rebooted, it booted up in hboot. I used rom manager to do this
    Can you get into recovery?
    Sent from my NookColor using Tapatalk
    yes I can go to recovery
    OK, we just need to get your system up and running again...
    Which recovery are you using, and which ROM are you trying to install?
    Yea I can go into recovery
    Sent from my HTC Glacier using Tapatalk
    I'm trying to put my working rom back on which is the miuiformels version 1.3.11
    What recovery did you use to make the backup, and do you still have the same recovery installed?
    I didn't backup my info cause I was changing roms
    I see...
    I would start by wiping everything, then trying to flash your MIUI ROM again.
    I would still like to know what recovery you are using?
    I used rom manager for my recovery
nexus one stuck on hboot
