Is there a way to clean the track ball ?
This is a discussion on Is there a way to clean the track ball ? within the Nexus One forums, part of the Google Phones category; looks like there's some dust in there....
Thread: Is there a way to clean the track ball ?
    Junior Member ninsei's Avatar
    I am chiming in because I want to hear how to clean the track ball.
    Junior Member rajeche's Avatar
    my track ball color turns black ha ha.... need the same help...
    Well I ASSUME that the same trick that worked with the black berries will work here. That is power down the phone, and get some of that high sanitizer and put a glob of to in the ball. Then roll the ball around all over till the hand sanitizer dries up.
    I have not tried this on the N1 yet, but used to do it with the blackberry curve I owned. Worked great on that phone and this track ball looks to be the same design to me.
    Obviously... this advice is use at your own risk! :D
    AT&T Nexus One - Not Rooted
    Wave Secure + Lookout
how to clean nexus one trackball
