USB Car Charger Light Stays On! (car is off)
This is a discussion on USB Car Charger Light Stays On! (car is off) within the Nexus One forums, part of the Google Phones category; I got a USB car charger that sits flush in the power socket in my car. It charges my phone just fine, the problem is ...
Member
I got a USB car charger that sits flush in the power socket in my car. It charges my phone just fine, the problem is that the light on the charger stays on forever, even when my car is off! I imagine it's very little power but it still worries me that it's sucking up battery. Is this normal? Also the darn thing is impossible to take out so its so labor intensive i just don't use it
Android.net is the premier
Senior Member
That's a function of your cigarette lighter. It must be constantly powered it sounds like. The power draw from the charger when it's not charging should be very little, I would imagine. When you're talking about a battery with 100, 200, ?? amps, the drain would be negligible. No worse than a car alarm...
Senior Member
Just a heads up, I am on my second car charger for my Nexus One...the instructions for both read to not have it plugged into the cig lighter when starting the car. (Two different models of charger)
My car's power outlets (it doesn't have a cig lighter) are always on and have power. I always unplug mine when not using it to charge my phone.
Member
For years, I have had various cell phone chargers plugged into my cigarette lighters almost permanently and never had a problem of any kind. I have never, however, left a cell phone plugged into one of them unattended.
Senior Member
Originally Posted by
India Whiskey Charlie
Lucky you, I am one of those direction followers here, it took me YEARS to leave my phone charger plugged into the wall outlet when I wasn't using it.
Friends of mine and co-workers have had theirs stop working form doing this which is why it took me a long time to do it.
I couldn't do that in my car though, the power outlet always has power on, I wouldn't want to wake up to a dead car battery.
Member
N1David
Does a cell phone charger draw anything if a cell phone is not plugged into it? I have not experienced any dead batteries from leaving chargers without cell phones plugged permanently into cigarette lighter receptacles.
Senior Member
N1David
Yes, the ones I have had do they both have a light on them that lights up as soon as it is plugged in.
Member
N1David
If it's just the light, I cannot see how a tiny LED would draw enough current to run down a battery. Then again, I'm not informed enough in this field to fully understand the ramifications...
Senior Member
N1David
Totally cool, I play by the rules and would rather be safe than sorry.
Senior Member
N1David
N1David
I have seen Motorola chargers with that use the USB lines to determine if there's a phone connected and if not, it disables the charger so the power is dead. I don't think that's common, however.
- You may not post replies
- You may not edit your posts
Forum Rules
android always auto charger
android charger that stays in
can a car charger stay on without the car on
car charger is on when car is off
car charger stays on
car charger stays on after car is off
car charger stays on when car is off
car phone charger light stays on
my car chargee stays on
phone charger led lights run down battery
stay active phone charger in cars
stero usb light stays on
usb auto light
usb car charger light stays on
usb light stays on car stereo
