Power Button again...
This is a discussion on Power Button again... within the Nexus One forums, part of the Google Phones category; Getting rid of pesky N1 plenty of phones out there that will do the job.
Got a crappy refurb off Voda Uk.
Issues at the ...
Junior Member
Issues at the mo.
On Off button. Not working properly again. If its there it should work period!!!!!!!!
GPS never worked on this unit " " " " " " " !!!!!!!!!!
Phone switches off periodicaly whats that all about GRRRRRRRRRRRRRRRRR!!!!!!!!!!
Battery life less than half a day unless you switch off every thing .. Whats the point of having it.
I had a Nokia 5800 could use the GPS for most of the day it worked it was acurate and it worked.
Could have it on Internet on all day and it worked
And Oh yes mmmmmm it worked. Get my point.
- You may not post replies
- You may not edit your posts
Forum Rules
android long press power for 10 seconds
android only power button long press again in 10 seconds
android power button long press
are you sure system recovery only power button long press again in 10 seconds
are you sure system recovery or only power button, long press again in 10 seconds.
power 10 seconds android
