Power Button again...
This is a discussion on Power Button again... within the Nexus One forums, part of the Google Phones category; So my power button is dyeing on this Nexus... again. This time I am way out of warrantee, but I do have my SquareTrade warrantee. ...
Senior Member
So my power button is dyeing on this Nexus... again. This time I am way out of warrantee, but I do have my SquareTrade warrantee. I am going to wait as long as the button holds out... but assuming it died TODAY and SqaureTrade cut me my replacement check TODAY. What phone is the best replacement? I am leaning towards the Nexus S because... well I like the Nexus pure Google experience, but I have not kept up with the smart phones since buying the Nexus (self-defense against phone envy LOL) so what do you all suggest?
AT&T Nexus One - Not Rooted
Wave Secure + Lookout
Android.net is the premier
Junior Member
If I had to pick a phone today, it would be hard to ignore the positive reviews of the Samsung Galaxy S 2, but if it's possible to keep using your N1, and you're really sold on the Nexus experience, it might be worth it to wait for the Nexus 3. In the meantime, you could use Screen Off and Lock to turn off the screen with the search button, and No Lock or Widgetlocker to turn it on with the volume rocker. To be honest, I haven't used the power button on my N1 in months. I rarely if ever have to reboot, so I'm hoping my power button lasts a good long while.
Good luck in whatever you choose
Senior Member
I should probably get those apps while the power button still works. Not a bad idea.
Junior Member
Originally Posted by
VydorScope
And don't forget that if your battery dies, you can turn it on by plugging in the charger and removing and inserting the battery. Not elegant, but it works!
Senior Member
MerkurMan
VydorScope
Yea, had to do that the last time when the power button was completely dead. Right now the power button works most of the time... but you can tell its going. Would prefer to wait and see what Nexus 3 would be like.
Senior Member
VydorScope
What color did you dye it? :rofl3:
Android Master
If your rooted there is a rom on XDA that uses vol-/vol+ in place of power button. Forgot which one.
[SIGPIC][/SIGPIC]
San Francisco Giants
Senior Member
rugmankc
No need to root the apps mentioned earlier in this thread do it. Think my plan is to hold off on warranty claim, use these apps and see what Nexus 3 looks like.
Android Master
Sorry, I only scanned the posts and missed them--good idea to wait on Prime. If Samsung, it may have a much better touch screen also.
Ken
[SIGPIC][/SIGPIC]
Senior Member
And, really, it's not that expensive to get HTC to fix it for you. I've had them fix the power button issue 3 times now. It cost $55 once, but that was due to the fact the phone was run over by a car, and needed a glass replacement. It got run over just before I was about to call them and get the power button fixed. 100 days later, I called again because I was back to using the power cable plug in method to turning it on, and they fixed it for free, including paying for FedEx shipping.
And T-Mobile will give you a loaner for free while your phone is in the shop. It'll be a crappy feature phone most likely, but you'll only be without your N1 for 4 or 5 days max.
I just don't see any phones that are worth giving up my N1 for at the current time.
The memory will be erased, so make sure you back up your stuff.
- You may not post replies
- You may not edit your posts
Forum Rules
android long press power for 10 seconds
android only power button long press again in 10 seconds
android power button long press
are you sure system recovery only power button long press again in 10 seconds
are you sure system recovery or only power button, long press again in 10 seconds.
power 10 seconds android
