Nexus One Wall Charger - AC Voltage Question
This is a discussion on Nexus One Wall Charger - AC Voltage Question within the Nexus One forums, part of the Google Phones category; Requesting folks who have received their N1's to kindly check if the input voltage on the wall charger supports both 110 V and 220 V ...
Results 1 to 10 of 10
Thread: Nexus One Wall Charger - AC Voltage Question
    Junior Member manikahuja's Avatar
    I travel a lot and need to know if the charger supports both input voltages or if i need to buy another one for 220 V input.
    Many Thanks
    Manik
    Junior Member jss1199's Avatar
    yes. 110v - 240v
    Phihong Adapter Model PSAA05A-38P
    Quote Originally Posted by jss1199 View Post
    yes. 110v - 240v
    Great, Thanks a lot for the quick reply. This solves a big issue for me
    Senior Member Spydaz's Avatar
    What he said....
    MOTO DROID & :nexusx:NEXUS ONE
    Junior Member djdefaz's Avatar
    Will a 100-240V wall charger work flawlessly with the nexus one?
    Member India Whiskey Charlie's Avatar
    Quote Originally Posted by djdefaz View Post
    The OEM charger says it's 100-240v.
    Quote Originally Posted by India Whiskey Charlie View Post
    Yeah but im in Australia and have a 100v-240v charger in front of me and dont know if it will work or brake my nexus one. The original us charger i received is 110v-240v. Just asking someone with expertise around this field if they know if it will work?
    Senior Member Iggy82's Avatar
    Worked for me fine on business trip to Finland last week. It'll work in any country (maybe not Russia though as Google are American, tee hee hee!)
    Junior Member raptor84's Avatar
    Working fine here in SG with a 240v socket
    Senior Member Rusty's Avatar
    I'm using the US charger in the UK with just an 80p shaver plug from ASDA, works fine... screw 20 bucks for the charger!
asus nexus 7 voltage 110 220
does nexus 7 have a duel voltage
does the nexus 7 tablet have duel voltage
is google nexus 5 dual voltage
is my nexus 7 dual voltage for travel
is necus 7 charger dual voltage
is nexus 7 dual voltage
is the nexus 7 tablet dual voltage
nexus 4 dual voltage
nexus 7 2012 dual voltage?
nexus 7 220v
nexus 7 european voltage
nexus plug dual votage
will the nexus 7 charge with 220
