Battery Life initial impressions?
This is a discussion on Battery Life initial impressions? within the Nexus One forums, part of the Google Phones category; wow that is good battery life much better than mine!...
Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 134
Thread: Battery Life initial impressions?
  1. #121
    Member Staker's Avatar
  2. #122
    Member Quantic's Avatar
    I think I learned quite a bit from the 3GS on how to get the most out of a somewhat poor battery. In my limited experience with the N1, I have noticed that there is a very dramatic difference between battery life when the screen is on lowest and brightest settings.
    I have also got locale setup, so that it knows when im outside of wireless areas and turns it off. Twitter apps seem to kill the battery as well, so ive got mine set up to only notify me when I get a direct message or mention.
  3. #123
    also check the sms bug noted in another thread
  4. #124
    locale the paid ap?
  5. #125
    Locale beta, its a free version
    EDIT: Sorry, the app i installed was actually Automatic Task Killer, not taskiller
  6. #126
    Junior Member denaeva's Avatar
    I charged my phone battery fully, it can lasts more than six hours.I think it's not enough !
  7. #127
    Junior Member Wendelius's Avatar
    My phone has been off the charger for 4 and a half hours. Over that time, I've made a couple of short phone calls, sent SMS's, browsed the web over 3G and played for 15 minutes with Google maps. The phone has been idle for 3 hours 20m (got to get some work done )
    The battery is now at 78%. No complaints here (and no automatic task killer).
    Wendelius
  8. #128
    my phone lasted 1 day and 4 hours last night, I had downloaded and tested some maps, done 1 hours worth of calls, 2hours of browsings plus some other stuff. It was at 15% when it asked me to charge. Brilliant!
  9. #129
    Member TerD's Avatar
    14 hours on 2nd charge
    Got my N1 Monday shipped to Brussels. First charge lasted about 8 hours. Second charge with a dozen calls, lots of browsing, YouTube etc lasted about 14 hrs.
    A fun toy, but forget about 2 or 3 days autonomy. Charge overnight, everynight!
    TerD
  10. #130
    Senior Member flow's Avatar
    You can always using the Battery use in About phone to understand what part of the phone used up all your battery. For Example, I use that to find out my GPS software keep running and used up 29% of of my power on my phone after one day of use. So I removed that software than every my Battery life is improved many.
  1. I'm new, too.
    By G2 Forum User in forum Introductions & Site Assistance
    Last Post: 11-11-2010, 11:34 AM
  2. Checkin In...
    Last Post: 10-08-2010, 09:50 AM
  3. Epic 4G Root Thread
