wifi not at&t edge
This is a discussion on wifi not at&t edge within the Nexus One forums, part of the Google Phones category; I'm using at&ts edge network with no data plan so is there a way to prevent the phone from using the network for browsing or ...
Thread: wifi not at&t edge
    Junior Member Rider500's Avatar
    wifi not at&t edge
    I'm using at&ts edge network with no data plan so is there a way to prevent the phone from using the network for browsing or emails? When i connect to wifi does the phone choose that over the network or does it pick whatevers faster? I dont wanna get a $300 bill next month cause i thought i browsing over wifi but it was actually the network. Thanks for any replies
    Member joker's Avatar
    so far, the behavior i've observed is this:
    If the N1 finds a familiar/working WiFi, it switches over to using that
    otherwise it will use 3G/2G network
    If WiFi is disabled, always uses 3G/2G
    since I have unlimited data, I just turned off wifi (also saves on battery)
    I'm not doubting you but is there a way you can tell if your using wifi or edge, and also does anyone know of any other applications that access the internet without you actually doing anything, I noticed the email did but I have that turned off any other app? thanks
    Junior Member Jocomp's Avatar
    You can call att and have them put a block on internet usage for your line, I did this with my unlocked iphone on att and just used it on wifi.
    Last Post: 12-07-2010, 08:42 AM
  2. why wont my phone connect to my computer
    Last Post: 10-14-2010, 09:04 PM
  3. list of accessories for the epic :-)
    Last Post: 08-14-2010, 04:07 AM
