PLEASE READ: Do NOT worry about Apps running in the Background
This is a discussion on PLEASE READ: Do NOT worry about Apps running in the Background within the Nexus One forums, part of the Google Phones category; Taken from DroidForums.net....Since the Nexus One is almost a Mirror to the Droid and this is the subject of several Posts. PLEASE READ: Do NOT ...
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: PLEASE READ: Do NOT worry about Apps running in the Background
    4 times
    PLEASE READ: Do NOT worry about Apps running in the Background - Droid Forum - Verizon Droid & the Motorola Droid Forum
    Originally post by cereal killer
    This subject has been talked about a lot in here since the Droids release. I've talked to a developer who is very well versed in Linux/Android and he summarized the following as correct......
    Android is different to most other phone operating systems. It's closer to Linux than any other type of operating system. Lots of services and applications constantly run in the background just like they do on Windows. However, and this is important, they do not have to use up a ton of resources. A service or app can be loaded, yet use almost no additional memory, and 0% CPU until it actually has to do something.
    In general, killing off stuff is a waste of time. Android automatically asks apps to close that aren't needed when it needs more memory. Killing off some of the processes you are killing off also means it'll slow your phone down, as these processes only need to reload, and when you do need to use them it means the phone will be slower for the few seconds it takes to reload them.
    Senior Member M_Woody's Avatar
    ah, good job posting this :D
    Junior Member barnettj's Avatar
    So I guess I should get rid of my task killing app. To be honest, I never could really tell a difference in speed any way. I was just being obsessive about it out of habits I developed from my Blackberry days.
    4 times
    Quote Originally Posted by barnettj View Post
    Came from BB myself, I know what your talking about. Nothing wrong with killing a rouge app that is not programed correctly, but in general Task Killing is not needed.
    Member blakmaj1k's Avatar
    Well this is good news to hear. One less thing to worry about now.
    Junior Member adboxz's Avatar
    Roger that!!
    Member wildrage's Avatar
    I'll still be using my task killer. If there are 25 programs running in the background, and I only have 25mb of memory free, it's not only going to bog down the phone, but its going to waste battery as well.
    I think its important to set your task killer to ignore system apps that will be restarted, such as voice dial, etc.
    Just my .02
    Senior Member TonyHoyle's Avatar
    No, it isn't. Idle apps don't 'bog down tne phone' and don't use any battery at all (you can check that in the battery usage page).
    Member whsnext's Avatar
    I just read that Google is gonna change around the way you download apps. So it saves to the SD card because of the memory problem. I know for a fact it slows my n1 once it even crash/rebooted it self. So I'm not going to stop killing apps. Until than. I even called HTC and an I.T told me the same. You can Google it if you dont believe me.
    I've *never* killed an app and my N1 is as fast as the day I bought it. Android is designed from the ground up to be used this way.
    Just read the very first post of this thread. That explains the whole thing. Read the thread it's linked to even.
    As for your first statement.. I presume you just misread it because I don't see what SD cards have to do with memory usage.
  1. Android Honeycomb Default Music Player App Leaked
    By dgstorm in forum Android News
    Last Post: 12-30-2010, 04:23 PM
  2. Samsung Epic with no money down and $100 credit to my account
    Last Post: 09-02-2010, 09:44 AM
  3. The Official Epic 4G FAQ
    Last Post: 08-04-2010, 12:57 AM
  4. The Samsung Behold II Android 1.6 Update Hits
    Last Post: 06-27-2010, 05:16 PM
data what is running in background
define magenometer compass
do apps running in background use data
do apps running in the background use data
do not worry about apps running in the background
droid dna maps running in background
nexus 4 app running background
