Camera sound
This is a discussion on Camera sound within the Nexus One forums, part of the Google Phones category; The camera shutter sound is pretty annoying. You can get rid of it by turning the ringer volume all the way down, but it would ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Camera sound
    Junior Member sglow's Avatar
    Camera sound
    The camera shutter sound is pretty annoying. You can get rid of it by turning the ringer volume all the way down, but it would be nice to just disable it.
    Has anyone found a setting to control this, or change the sound the camera makes?
    Senior Member Roxy's Avatar
    I'm wondering the same thing. The shutter sound is annoying ~ >_<
    [ Cyanogen 5.0.5.6 | OC'ed to 1.113GHz | Amon RA v1.70 | Build EPE54B| Desire Camera R2 | NexTHEME 2.0 Final & Goodies5 R2 ]
    Member Jaredu's Avatar
    there's no real way to disable it unfortunately.
    All camera phones at some point may be required to make a noise, consider turning the volume down to make it disappear a convenience: In japan all cameraphones must make a noise due to pervs sticking their camera under camera stalls and skirts.
    4 times
    Junior Member Phydeaux_nexusone's Avatar
    Quote Originally Posted by Backnblack View Post
    Ok... the creepyness of this thread just went way up.
    Junior Member jsjames's Avatar
    I take pictures at stores of designs for work, so it helps me to not have it makes a sound. I use Camera Zoom FX, it has an option to disable sound.
    Senior Member flow's Avatar
    you can do it before open up your camera software silent your phone by using volume down, or just using the SilentMode onOff, or other software. now you can take picture without a sound. You need to re-enable the sound after finished to play with your camera.
    Member !!11oneone's Avatar
    I'd have thought, with a rooted device, you could replace the sound clip that plays with a blank one.
    Don't quote me, though. I know very little.
    Member Eric_nexusone's Avatar
    Well, guess that you just have to use a app when taking pictures on girls shirts.. haha
    My worry is that the sound will wake people up when I've crept into their bedroom at night.
    Thankfully the video app doesn't make a noise.
  1. e-mail updates
    Last Post: 09-01-2010, 01:41 PM
android camera sound
android camera sound off
android camera sounds
android camera voice
change camera shutter sound android
google nexus camera sound
how to change camera shutter sound in android 6.0
how to close camera sound android
how to sound of camera in nexus s
how to turn off camera sound on nexus s
htc nexus one camera sound off
nexus 5 camera shutter sound
nexus s camera sound
turn off camera sound nexus s
