Will the current (T-Mobile) N1 work on Verizon when they are ready?
This is a discussion on Will the current (T-Mobile) N1 work on Verizon when they are ready? within the Nexus One forums, part of the Google Phones category; I purchased the unlocked GSM N1 to use on the T-Mobile month-to-month service. But might want to switch to Verizon when they are ready. Is ...
Results 1 to 10 of 14
Thread: Will the current (T-Mobile) N1 work on Verizon when they are ready?
    Junior Member RealtorRyan's Avatar
    I purchased the unlocked GSM N1 to use on the T-Mobile month-to-month service. But might want to switch to Verizon when they are ready. Is the current phone capable of handling Verizon's network? Or must I get a new phone completely?
    Member milkjuice's Avatar
    I am sure you'll be able to use it for verizon when they come out with it, they're coming out with CDMA I believe in spring. I'm not too certain though.
    Also there 3G bands are different.
    Member Jaredu's Avatar
    Quote Originally Posted by RealtorRyan View Post
    the one you have currently is a GSM phone, so no, it won't work.
    if you plan on switching you'll need to get the CDMA version with no sim card.
    Ohh, but the commercials say they have the best 3g coverage in the nation! :P facepalm.jpg @ Verizon.
    Is there proof somewhere that the current GSM N1 doesn't also have the CDMA tech as well. A la "world phone?"
    The FCC's only cleared this one for GSM. It says what bands it supports on the specs page of Nexus One Phone - Web meets phone.
    Member joker's Avatar
    Ryan
    Yes. It's in the technical specs. There is NO CDMA version. GSM ONLY.
    And for your info, CDMA has nothing do with the world, no one outside the USA uses CDMA.
    In other words, if you have your verizon (or sprint phone) anywhere in Europe.
    You will have no service at all.
    4 times
    Quote Originally Posted by joker View Post
    True, but there is not a better network in the US...And yes, I've used them all....
    Quote Originally Posted by Backnblack View Post
    That depends completely on your location.
  1. Google Voice Gets New Widgets on G2
    Last Post: 11-26-2010, 11:07 AM
  2. Samsung Vibrant vs T-Mobile G2?
    Last Post: 10-05-2010, 11:51 PM
  3. Got a samsung vibrant on my possession
    By DF Member in forum Samsung Vibrant
    Last Post: 10-02-2010, 11:08 AM
  4. Anyone upset with the Epic 4G price tag?
    Last Post: 08-25-2010, 12:49 PM
attila n1 mobile
realtorryan.com/2010/09/
