Possible solution to the 3G problem some are having
This is a discussion on Possible solution to the 3G problem some are having within the Nexus One forums, part of the Google Phones category; Originally Posted by fujitsupalm Originally Posted by sotorious Can someone tell me what 3g speeds are suppose to be. It really depends on who your ...
Results 11 to 13 of 13
Thread: Possible solution to the 3G problem some are having
    Quote Originally Posted by fujitsupalm View Post
    Quote Originally Posted by sotorious View Post
    It really depends on who your carier is. 3.5G is supposed to have the max potential of 14mbs if i remembered correctly.
    However, that's not really a reference point.
    If you're concerned with the speed of your provider, go look up some consumer reports / reviews.
    Some of them have dones speed tests at different spots to give you an idea on how your provider is treating you (or cheating you).
    Well obviously my provider is t-mobile i just wanted to know the avarge speed.
    Junior Member fujitsupalm's Avatar
    Sorry it's not obvious to me cos I don't live in the US.
    T-Mobile 3G to get speed boost later this year – Android and Me
    Check it here, they show some max potentials it can reach, the ole 3G at 1mbs, the new hsdpa will go max on 21mbs (highly unlikely when applied practically) hspa at 7.2mbs.
    so expect it to fall somewhere between 2 to 4 mbs should be decent enough.
    Thanks you.
