Nexus One screen color problem under low brightness setting
This is a discussion on Nexus One screen color problem under low brightness setting within the Nexus One forums, part of the Google Phones category; Hi, I just wanted to see if this is a quality issue or not. My Nexus One has this problem: when the screen brightness is ...
Thread: Nexus One screen color problem under low brightness setting
    Junior Member foxthewhite's Avatar
    when the screen brightness is set to low, the whole screen color becomes purple-ish. The lower the brightness the more purple-ish it gets...
    Is it a normal behavior or just my phone's quality problem?
    Thank you very much
    Senior Member TonyHoyle's Avatar
    Sounds like a faulty phone. Even a minimum brightness my phone is bright and clear (in fact I've never yet needed to have it at anything other than minimum).
