Setting Speed Dial?
This is a discussion on Setting Speed Dial? within the Nexus One forums, part of the Google Phones category; How can i go about setting some of my contacts as a speed dial number? For example, if I want to set my brother's number ...
Results 1 to 10 of 13
Thread: Setting Speed Dial?
    Junior Member RickFriedman's Avatar
    Setting Speed Dial?
    How can i go about setting some of my contacts as a speed dial number? For example, if I want to set my brother's number so that he is called simply by pressing and holding the number 2 key, how can I do it? Maybe I can't?
    Rick
    Senior Member Fuse's Avatar
    Not sure you can do that.
    How about this. Hold desktop -> Shortcut -> Direct Dial ->Select your contact
    That will add a speed dial to your homescreen. Not su
    Rooted Nexus One
    Junior Member saetam's Avatar
    Quote Originally Posted by Fuse View Post
    Nice! I didn't know you could do that! Thanx a ton!
    np.
    It's also nice to just add the contact (instead of direct dial) which will bring up all ways to contact them or look up their info.
    Rooted Nexus One
    Member TBird1's Avatar
    Sweet !!
    Member idiort's Avatar
    i normally just favourite them.. then just go to favourite...
    What this phone don't have speed dial?
    even the most basic of phone (cheapo) have speed dial
    Android Lurker iPeck's Avatar
    Laval, Qc
    you have an app called speed dial on the market
    Thanks, I'll check it out but still missing the basic of functions on a "smartphone" is kinda sad.:D
    Shouldn't have to install anything extra to get speed dial.
    Who needs speed dial when you have a contact list and favourites that is what I do and it works fine I guess if you have like 150 contacts then it might be helpful but once again that is what favourite is for so whatever I guess itís just a choice.
  1. Battery Life + Info Re: Desktop Dock
    Last Post: 09-06-2010, 07:57 AM
android speed dial settings
android speed dial setup
how to set up speed dial on fire phone
how to set up speed dial on s4
how to set up your one touch dial on your fire phone
how to setup speed dial on nexus s
how to speed dial on nexus s
nexus 4 speed dial
nexus s 4g speed dial
setting speed dial on android
speed dial fire phone
speed dial nexus s
speed dial nexus s 4g
speed dial on google nexus
