Adding a Bluetooth headset and battery life.
This is a discussion on Adding a Bluetooth headset and battery life. within the Nexus One forums, part of the Google Phones category; I been thinking about getting a bluetooth headset but im worried about my battery life decreasing. how many of you guys are using one? Whats ...
Thread: Adding a Bluetooth headset and battery life.
    I been thinking about getting a bluetooth headset but im worried about my battery life decreasing. how many of you guys are using one? Whats the major difference in the life?
    Senior Member number 9's Avatar
    If it's anything like my Blackberry, it definitely drains quicker, although not substantially. Having an extra radio turned on and in use will drain more power. I'm never really that far from a charger/usb port, so it's mostly a non issue, unless you're out and about. Bluetooth is a must for me though, personally.
