Need tips on battery life
This is a discussion on Need tips on battery life within the Nexus One forums, part of the Google Phones category; One of my few complaints about the N1 is meager battery life. No way I can get a full day's use. Would appreciate any tips ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Need tips on battery life
    Junior Member blacter's Avatar
    One of my few complaints about the N1 is meager battery life. No way I can get a full day's use. Would appreciate any tips on keeping the battery going longer.
    stp
    stp is offline
    Junior Member stp's Avatar
    I turned off the live wallpaper, the battery runs much longer for me.
    Senior Member Fuse's Avatar
    yeah, Live walpapers kill it quickly...
    Rooted Nexus One
    Member 640k's Avatar
    Quote Originally Posted by blacter View Post
    goto home - menu - settings - about phone - battery usage and monitor what is your #1 killer for battery use. you should be able to go a full day without having to charge your phone.
    Thanks folks. Well, live wallpaper has been off, so that's not the issue for me. When I search on Battery Use, I see:
    Display 48%
    Cell standby 35%
    Phone idle 5%
    Mediaserver 4%
    Android System 4%
    Android OS 2%
    Wi-Fi 2%
    I don't know what to make of those numbers, so would appreciate advice.
    Am I the only one with disappointing battery life? Maybe my phone or battery has an issue.
    Junior Member digitaldisaster's Avatar
    Its all on how you use it.
    If Im at work using it light to moderately I have all settings maxed out.
    If I know Im going to be away from a power source all day, I'll drop my display brightness to lowest. That tends to consume the most.
    Member raccord's Avatar
    Display 48%
    Cell standby 35%
    Phone idle 5%
    Mediaserver 4%
    Android System 4%
    Android OS 2%
    Wi-Fi 2%
    i have similar specs on my battery use and battery life is terrible. so you aren't alone
    Junior Member Finishlinewrx's Avatar
    Turn off live wallpaper
    If your not in 3g area lock the phone to 2g.
    Turn off wifi when not in use.
    Turn off bluetooth when not in use.
    My screen is set to auto brightness.
    Look at some fetch/push whatever settings on email and such. Mine checks every 30 min. The more often the more battery.
    Senior Member gregornz's Avatar
    In my experience the display uses between 60 and 80 percent of the battery.
    So, turn the brightness down, and don't turn the screen on every 2 minutes to gawk at the beauty of the phone and you should save a lot of juice.
    Senior Member Rusty's Avatar
    I have mine on the lowest brightness setting and turn off things when I don't need them, battery life is about the same as my N95 so think I'm doing alright.
nexus 7 longer battery life tips
