permenent power on ?
This is a discussion on permenent power on ? within the Nexus One forums, part of the Google Phones category; If i have the phone plugged in and charging whilst in the car (using the USB lead) is it possible to have the display permenently ...
Thread: permenent power on ?
    Member acabbie's Avatar
    If i have the phone plugged in and charging whilst in the car (using the USB lead) is it possible to have the display permenently on or does it shut off after the specified time ?
    I've looked for settings to allow the phone display to remian on when plugged into a power source but so far can only find the standard setting that allows it on for up to 30 mins.
    cheers.
    Member minedune2's Avatar
    There is actually an option for this on the phone, Its just not were you would expect it to be.
    You go into settings then go under "applications" then go under "development" and check off "stay awake" this will keep the screen on while plugged in.
    Member odhinn's Avatar
    how about per app? or per state?
    I'm in the same boat. I have my N1 plugged into my car stereo for charging and music and it always powers off and locks which is annoying.
    I'll try those two options, but I'm wondering if there's a way to control it per app.
    e.g.
    if MixZing is running and power is present
    turn off screen at system-specified timeout
    don't lock screen unless power button is pressed
    turn screen on when anything is pressed
    I don't mind my screen going dim or turning off as long as I don't have to unlock my screen when I want to change the music, etc.
    Anyone?
    cheers.........
  1. Garminfone that much better then Google Maps?
    By TMODroids User in forum Unlisted Android Phones
    Last Post: 06-25-2010, 12:11 AM
