Innocell 1600mAh Slim Extended Life Battery for Nexus One
This is a discussion on Innocell 1600mAh Slim Extended Life Battery for Nexus One within the Nexus One forums, part of the Google Phones category; Innocell 1600mAh Slim Extended Life Battery for Nexus One Seidio invests in extensive research to find the best and most powerful battery components on the ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Innocell 1600mAh Slim Extended Life Battery for Nexus One
    Member seidioseidio's Avatar
    Seidio invests in extensive research to find the best and most powerful battery components on the market. We carefully select top quality Japanese cells for our batteries to ensure the highest level of safety, quality, and performance. Our research, knowledge, and expertise give us the ability to create batteries that provide maximum capacity in their comparable space. This Innocell Extended Life Battery is designed for the customer who needs extra life, but doesn't want to add any thickness to their device. This model fits in your device's existing battery space and doesn't require a replacement door, which makes it a perfect replacement for your original battery.
    - Made from the highest quality Japanese cells
    - More capacity in the same form factor
    - Fits in existing space so no replacement door is needed
    - Perfect replacement for your original battery
    - Capacity: 1600mAh
    * All battery life claims are dependent upon usage patterns, network configuration and many other factors; actual results will vary.
    Pre Order Now Available!
    Member tribz's Avatar
    How much extra life?
    Junior Member icebrg1978_nexusone's Avatar
    Just Ordered Mine.
    Quote Originally Posted by tribz View Post
    Stock battery is at 1400mAh.
    A little bit more than 14% increase over the stock battery.
    Junior Member NexusVZW's Avatar
    Quote Originally Posted by seidioseidio View Post
    - Capacity: 1600mAh
    Will there be a bigger than 1600mah available???
    Metro Atlanta
    53 times
    I think they have said that they are working on an even larger capacity battery, one that will come with a replacement battery door to accommodate the larger cell.
    I wonder if a case will be made as well to accommodate the 5mm increase
    Senior Member Bob Loblaw's Avatar
    Got mine today. Anyone got any tips on the best way to optimize this thing? Do I need to run through several cycles of drain/charge?
    Senior Member disbj4ke's Avatar
    if someone who has received theirs could post how much life this battery is giving them it would be greatly appritiated. Thank you in advance.
    Banned DocMjldds's Avatar
    I should have mine tomorrow. I will post results ASAP.
