Aesthetics problem: A few dark spots on the Rubber surface
This is a discussion on Aesthetics problem: A few dark spots on the Rubber surface within the Nexus One forums, part of the Google Phones category; Are all of you guys experiencing this using the case? That's pretty messed up if HTC wont replace them then. But believe me apart from ...
Results 11 to 14 of 14
Thread: Aesthetics problem: A few dark spots on the Rubber surface
    Senior Member Zindol's Avatar
    Are all of you guys experiencing this using the case? That's pretty messed up if HTC wont replace them then. But believe me apart from smudgy finger prints on the phones screen it really doesn't need a case. Mine is still scratch free.
    Junior Member bmwe30is's Avatar
    Hey everyone,
    I was able to get a hold of a Gizmodo editor. Can anyone take pics of their discoloration and send them to either me or her? I can even provide her email address confidentially to those of you that do have photo's.
    My point and shoot can't pick up the discoloration that well and my dSLR is not with me
    Thanks!
    Jonathan
    i have the same issue...i was wondering wtf that was glad to finally figure it out...
    Member soongteck's Avatar
    Quote Originally Posted by ezeddiekun View Post
    Well I called HTC a couple of days ago. They said they have never heard of this problem, they denied it was at their fault. The only option they gave me was to take a risk by sending it to HTC and having them inspect it. This is just outragous, don't know if I'll ever buy from HTC again. Luckily Motorola is building the next Nexus.
    Google said that HTC will still be building the next business phone
dirty spots on handphone casing
how fo you get rid of black spots on a rubber cell phone case
how to clean black marks off a rubber cell phone case
how to get black stain out of rubber handphone casing
how to remove black marks cellphone case
how to remove black marks on cell phone cases
how to remove black stain on rubber phone cover
how to remove black stains on rubber case
how to remove handphone plastic cover stain
how to remove tains on rubber caseof cellphones
remove dark spot on phone case
removing stains on back of handphones
rubber cell phone cases stain
spots on tablet screen surfaces
