Aesthetics problem: A few dark spots on the Rubber surface
This is a discussion on Aesthetics problem: A few dark spots on the Rubber surface within the Nexus One forums, part of the Google Phones category; I noticed that there are a few visible dark spots on the rubber side of my Nexus One. No matter how hard I tried, I ...
Results 1 to 10 of 14
Thread: Aesthetics problem: A few dark spots on the Rubber surface
    Senior Member NexusDro's Avatar
    I noticed that there are a few visible dark spots on the rubber side of my Nexus One. No matter how hard I tried, I couldn't wipe them off. I am not sure where those dark spots come from and it seems like they were there since I got the phone. If it is really some dirty stain, how do you remove it?
    Thanks for the help in advance.
    Quote Originally Posted by NexusDro View Post
    I have the same exact problem. Its discoloration if the Teflon Coating. Calling HTC tomorrow too see if I can get mine replaced. Apparently some speculated that it is caused by the seams of the cloth case the phone came with. I have 4 spots on my bottom of my phone, annoying as hell.
    Quote Originally Posted by ezeddiekun View Post
    That sucks. And I tried to wipe it hard LOL. Can I buy something to recoat it?
    Hmm I don't know ima look right now
    Let me know if you find anything. I will do the same.
    hey ezeddiekun, any updates on the problem? I don't want to get a refurbished replacement just for that few spots. Do you know if others are experiencing the same problem?
    Senior Member Rusty's Avatar
    I've seen it mentioned in a few places, so it's not just you
    Junior Member bmwe30is's Avatar
    Hi all,
    I'm also experiencing this issue. It's been documented here as well:
    Discolorations on Nexus One metal - Android Help
    Not spamming... I'm just really annoyed after paying so much money for the device, it shows this type of wear after just 3 weeks of daily use.
    My little plastic Nokia didn't show any wear for nearly weeks / months after purchase!
    Are there enough of us to make a case to HTC? I already have a ticket established with them and I'd be more than willing to submit a letter to them to show how annoying and widespread this problem really is.
    Senior Member madchyers's Avatar
    I've seen this on my friend's nexus. He showed me today. Its at the bottom of his phone, like 4 small dark spots near the USB charge spot. He said he thinks its from the case HTC gave us.
    Well I called HTC a couple of days ago. They said they have never heard of this problem, they denied it was at their fault. The only option they gave me was to take a risk by sending it to HTC and having them inspect it. This is just outragous, don't know if I'll ever buy from HTC again. Luckily Motorola is building the next Nexus.
dirty spots on handphone casing
how fo you get rid of black spots on a rubber cell phone case
how to clean black marks off a rubber cell phone case
how to get black stain out of rubber handphone casing
how to remove black marks cellphone case
how to remove black marks on cell phone cases
how to remove black stain on rubber phone cover
how to remove black stains on rubber case
how to remove handphone plastic cover stain
how to remove tains on rubber caseof cellphones
remove dark spot on phone case
removing stains on back of handphones
rubber cell phone cases stain
spots on tablet screen surfaces
