Help please with feedback noise in car
This is a discussion on Help please with feedback noise in car within the Nexus One forums, part of the Google Phones category; I have the N1 and also have a New Alpine iXA-W407EBT in car touch screen stereo player. The problem I have is that I can ...
Thread: Help please with feedback noise in car
    Member ndwgolf's Avatar
    I have the N1 and also have a New Alpine iXA-W407EBT in car touch screen stereo player. The problem I have is that I can continually hear the N1 trying to connect to the car stereo.............. it sounds like if you are listing to a radio and just before your phone rings you get that feedback noise through the radio, well when I am in the car I get that noise all the time, if I put the N1 into airplane mode it goes away.
    Do you think the problem could be with the N1 or the Alpine stereo????
    Member Pegasusrider's Avatar
    This happened with my husband's stereo, a CAR TOYS installation. When he did the research, turns out it does not cover the cell phone as one of it's devices. Check for an update for your system, and see if it has been updated, if not may have to get a blue tooth like my hubby.
    Pegasusrider
    I LOVE my Nexus One:
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by Pegasusrider View Post
    Hi the phone connects to the stereo without a problem, I can make calls with the hands free and stream music via bluetooth but I keep getting this constant feedback noise
    Quote Originally Posted by ndwgolf View Post
    Under normal circumstances, most if not all speakers will make noise just before the a cell phone rings; this is more apparent with the phone close to the speaker /s.
    This is because a electrical wave is produce during ringing / vibrate from the phone which is picked up and resonated by the magnet / coil of the speaker.
    If you are getting this constantly it is just the sensitivity of your system and I don't believe you can do much with your problem, other than place your phone in another location in your vehicle.
feedback noise on phone in car
