3200 mah Battery: WHEN!?
This is a discussion on 3200 mah Battery: WHEN!? within the Nexus One forums, part of the Google Phones category; They have it available Innocell 3200mAh Extended Life Battery It sounds tempting... but it means I won't be able to use the Nexus one dock... ...
Results 11 to 18 of 18
Thread: 3200 mah Battery: WHEN!?
    Android Lurker lunchbox's Avatar
    It sounds tempting... but it means I won't be able to use the Nexus one dock... still thinking.
    Junior Member ufoDziner's Avatar
    Well, it came but I had to go out of town. So, it's sitting at home. Once I get back, I'll take some pics, etc...
    Senior Member E-man's Avatar
    Ew. It adds about 25% girth and if you had it engraved then you won't be able to view it.
    seidioonline.com
    I don't mind the thickness.. but would hope they can slim the lower part so I can still use the google dock.
    Well, it's on and all charged up. The back cover is black plastic, with a similar coating on it to the stock cover. However, it feels a little cheaper. Also, it doesn't fit exactly perfect down towards the bottom, where it extends past the original cover area. The phone is thicker, but not by much. To me, it actually feels better in my hand because of the thickness. The camera holes, are just that. Holes. No protective glass over the lens like on the stock case. It also does feel heavier, but not that much. I don't have a scale that is sensitive enough to weigh the difference. I'll get some pics up as soon as I can.
    Quote Originally Posted by seidioseidio View Post
    Hello All,
    Thank you for your interests! The Innocell Super Extended Life Battery should be available within the next week or so. Once it becomes available, we will make an announcement on the forum!
    Regards,
    Does the phone's battery indicator register the extra cells to keep an accurate gauge?
    Yes, it keeps an accurate gauge.
    And... Here are the pics. Let me know if you have any questions.
    Junior Member FazliS85's Avatar
    Quote Originally Posted by ufoDziner View Post
    Thanks for posting the pics. Though it might be practical, im not digging the looks! I think I might just stick with an extra reg battery for now.
  1. Epic 4G Root Thread
10mah=?hours
3200 mah android battery
3200 mah hours use
3200 mh battery hours
android phone 3200 mah
babo 3200mh battery for s3
hoow much is 3200 mah
how many hours is 3200 mah
how many hours is 3200mah
how many hours of battery is 3200mah
how much a 3200 ma battery can use
how much is 2.1 mah battery
how much is 3200 mah
how much is 3200 mah in percentage
how much is 3200mah
