battery life while using navigator :( WOW
This is a discussion on battery life while using navigator :( WOW within the Nexus One forums, part of the Google Phones category; ok i started with 88% started navigator used for 40 minutes and made 1 call.after that i had 28%........... is that normal? also when i ...
Results 1 to 10 of 17
Thread: battery life while using navigator :( WOW
    Junior Member pazatat2's Avatar
    ok i started with 88% started navigator used for 40 minutes and made 1 call.after that i had 28%........... is that normal? also when i got home i started to charge it and it got hot not warm,could this be a deffective handset?
    Junior Member Chrisrider's Avatar
    That sounds about right. You are using GPS, data, and Nav all of those load the battery pretty good. you might want to get a car charger next time. The warm battery while charging is normal too just so long as it doesn't stay warm all the time.
    hotter than those hand warmers you crack open? that cant be right it gets real hot
    It might be a good idea to call Google tech support then.
    Quote Originally Posted by Chrisrider View Post
    just got off the phone and they said it is normal. wow doesnt seem normal
    when i had plenty other phones yeah they would get warm but not HOT
    Junior Member SeeRad's Avatar
    Quote Originally Posted by pazatat2 View Post
    Is there a car-dock with fans to cool it? I'd imagine if it gets too hot some internal soldering might disconnect, a la the 360s' heat-sinks.
    Senior Member Macklessdaddy's Avatar
    when my phone was new as in the first few days it also got hot not warm but hot then it just stopped on its on.
    4 times
    You forgot the biggest power user...The Display.
    Member FastMhz's Avatar
    Definitely purchase a car charger.
    Senior Member dg36's Avatar
    +2 on charger...... My Garmin doesn't last for more than a couple hours without a charger!
