After charging battery...
This is a discussion on After charging battery... within the Nexus One forums, part of the Google Phones category; So it it not good to charge your phone while sleeping? Cuz every time i disconnect the charger from my phone, my nexus freezes. my ...
Thread: After charging battery...
    Junior Member jenjenkim's Avatar
    So it it not good to charge your phone while sleeping? Cuz every time i disconnect the charger from my phone, my nexus freezes. my touchscreen wouldn't work and i tried turning it off and it wouldn't. it took a good minute before my phone came back alive. You think it's due to overcharging? If so, whats the max charging period?
    Junior Member NexusMechs's Avatar
    I presume you aren't using and official charger?
    Never happened to me.
    Thank God.
    I can see it being an app issue. Are you using an app that displays or monitors battery charge?
    I can't see how a charger would do this unless it was under-/over-voltage or way under-current maybe.
    Also could be a phone hardware issue. :nexusx:
    AT&T ne:nexusx:us S on AT&T
    Archos 70 with UrukDroid
    hmmm...is it bad to leave your phone charged all nite?
    Member FastMhz's Avatar
    Quote Originally Posted by jenjenkim View Post
    Nope.
    I leave it overnight. I'm not going to wake up in the middle of the night and unplug my phone.
    Quote Originally Posted by iPhoneSlayer View Post
    Thank God.
    +1, Luckily I also haven't had that problem.
android hangs while disconnecting charger
battery charge problem after firmware upgrade note2
nexus 5 phone freezing after charging
