To anyone having any tech problems with their N1
This is a discussion on To anyone having any tech problems with their N1 within the Nexus One forums, part of the Google Phones category; I know it sounds ghetto, but turn off your phone, remove the battery, sd card and sim card. Blow away any dust inside. Wait about ...
Results 1 to 8 of 8
Thread: To anyone having any tech problems with their N1
    I know it sounds ghetto, but turn off your phone, remove the battery, sd card and sim card. Blow away any dust inside. Wait about a minute and put everything back together. Then turn on the phone and see if the problem(s) goes away.
    It worked for my touchscreen issues...for now. Hey, it's worth a shot.
    Junior Member thiago's Avatar
    So, you are basically saying that, after rebooting the phone, the touchscreen issues go away? lol
    Senior Member SubyWill's Avatar
    lol
    10charrrr
    This sounds like pure luck to me LOL
    Not lucky, if you're having touchscreen issues, just reboot the phone and it will go away (not permanently though). No need for voodoos :P
    Reminds me of my old nintendo cartridges...
    Quote Originally Posted by soulstar View Post
    LOL..exactly! Man, sometimes you had to jump through hoops just to play a game.
    BTW. I knew it was a long shot but it was worth a shot....stranger things have happend.
    Senior Member Rusty's Avatar
    Quote Originally Posted by thiago View Post
    Don't even have to do that, just locking and unlocking will sort it.
  1. T-Mobile announces Dell Streak 7, it's first 4G Tablet
    By JohnDroid in forum Android News
    Last Post: 01-06-2011, 02:22 PM
