Can't get the battery door opened.
This is a discussion on Can't get the battery door opened. within the Nexus One forums, part of the Google Phones category; I am having a hard time trying to open the battery door. I tried so hard and I could hear some cracking sound coming out ...
Results 1 to 8 of 8
Thread: Can't get the battery door opened.
    Senior Member NexusDro's Avatar
    I am having a hard time trying to open the battery door. I tried so hard and I could hear some cracking sound coming out of the battery door. I don't want to break my phone. How am I supposed to open it? I want to swap SIM cards
    Senior Member Zindol's Avatar
    Holding it down with your 2 thumbs and pushing it upwards should do the trick. It shouldn't be a struggle though. Have you dropped the phone previously or something to disfigure it?
    Where do you place the two thumbs? Slightly below the camera or in the middle of the door? Or lower corners of the door? I have never dropped the phone. The battery door is just too tight.
    The lower corners and pushing upright normally does the trick. If thats not working, something is up. I can't figure out what though.
    Ok, I got frustrated and used more force to get the battery cover out. I hope it didn't squeeze the phone and the glass screen too hard. I don't think it would desensitize the touchscreen, right?
    As strong as the phone is I doubt it would. Glad you managed to open it.
    Senior Member thomaslkuo's Avatar
    I had that same problem at first, now I think muscle memory has taken over and I open it just fine. That or the cover has loosed its death grip.
    It's impossible to avoid pressing on the screen while opening the battery cover.
  1. Epic 4G Root Thread
cant open phone batter door
how to open a google nexus battery door
how to open a nexus one
how to open nexus one battery cover
nexus one remove battery
remove nexus one battery
