Can't read/write to microSD card
This is a discussion on Can't read/write to microSD card within the Nexus One forums, part of the Google Phones category; hi all, I connected my Nexus One to my Windows XP laptop. It appears as a drive E: but I'm unable to read it, much ...
Results 1 to 10 of 10
Thread: Can't read/write to microSD card
    Junior Member jakeqT's Avatar
    hi all,
    I connected my Nexus One to my Windows XP laptop. It appears as a drive E: but I'm unable to read it, much less write to it? I believe a saw a pop-up the first time i connected it (was that the Mount prompt?). I no longer get a pop-up now when i connect to the USB port.
    Any advice would be appreciated!
    p.S. also, just to make sure i could write to the card, i copied my 1000 contacts to the card, yet the diagnostic tool says the card is still 99% empty! what goes?
    Senior Member Fuse's Avatar
    when connected it should give you the option to mount the SD card to the computer. You can also check the settings under SD Card and Phone Storage when it's connected.
    Rooted Nexus One
    Senior Member Zindol's Avatar
    Connect it to your PC then where you get notifications on your phone, drag that down and select the notification that indicates your phone is connected to the PC. Then select 'mount card's or something like that.
    Make sure you turn off the card through the same notification when you're done too.
    Ok - will try that. Thanks guys!
    -jake
    microSD card - part 2
    BTW, i formatted the card on the phone and ended up deleting all the songs that came with the T-Mobile SD card. Hope they weren't worth keeping.. :-(
    Another question: can you control what gets stored on the phone and on the microSD card? For examples, do photos get stored on the card? I know that apps don't get stored on the card, so what does?
    Thanks in advance!
    -jake
    Quote Originally Posted by jakeqT View Post
    Thanks in advance!
    -jake
    You don't have to format the SD card. I think photos and stuff are already set to copy to the card.
    Yes, I found that out. I eventually deleted the songs that came with from T-Mobile.
    My question is - what gets stored on the microSD card (unless manually placed there?) Do photos get stored on the card?
    -jake
    -jake
    I believe everthing gets stored on the card, except for market apps.
    ok thanks.
    There are several file manager apps that will allow you to see and manage what is on the SDHC card. I use ES File Manager, which also enables you to use WiFi to transfer files to/from computers on your local network.
android 4.4 can't write to sd card
android can't read sd card
android can't see microsd card
android can't write to sd
android can't write to sd card
android cannot write to sd card
android cant read sd card
android cant write to sdcard
can't write to sd card android
can't write to sd card on android phone
cannot read sd card android one
cant read sd card android
computer cannot write to android sd card
kitkat android apps can't write on sd card
unable to write to micro sd android
