Does the phone charge when plugged in to USB?
This is a discussion on Does the phone charge when plugged in to USB? within the Nexus One forums, part of the Google Phones category; Originally Posted by Matchbook I just got my Nexus One! Do I have to charge it completely before using it for the first time? I ...
Results 11 to 18 of 18
Thread: Does the phone charge when plugged in to USB?
    Android Lurker maris's Avatar
    Quote Originally Posted by Matchbook View Post
    I think that's a good idea. It shouldn't hurt to peek while it is plugged in and charging if you can't wait. I know many who say they did that.
    Junior Member Matchbook's Avatar
    Okay thanks. I think I will wait just to be on the safe side. I assume the 'notification light' is the little orange dot on the top right of the front of the phone?
    Yes. The orange dot will turn green when it's "almost" charged. I have to leave mine on an extra 10 minutes or so after it turns green to get to the fully 100%.
    Congrats !!!
    Junior Member Random Letters's Avatar
    Quote Originally Posted by ardynine View Post
    Not sure why you would want that anyway.
    Because I need to charge mine at work as well as at home if needs be, and I don't want to lug around the AC cord.
    Member Solipsist8's Avatar
    Quote Originally Posted by Random Letters View Post
    It will pull 500ma charge from any USB connection, if it needs it.
    Banned Chillrays's Avatar
    Yes. I have heard from alot of people that is strongly recommended that you do that. I even heard from one person to charge the phone an extra two hours after the green light comes on. The green light just means that the phone is 95% charged but I bet you'll be overly excited at that point. Enjoy your new phone.
    Senior Member ardynine's Avatar
    With lithium based batteries it really isn't necessary to charge it to 100% before first use. It doesn't matter at all. That's more of a habit left over from NiMH type batteries.
    Of course you don't need to take my word for it and it doesn't hurt to charge it all the way. Just don't worry too much about it.
    UK
    8 times
    Nd1razor
    What the guy above said, when the green light comes on, charge it longer, an hour should be good,
    using it before the green light turns up will kill your battery life...
  1. First Look at Sony Ericsson Xperia Arc
    Last Post: 01-17-2011, 05:23 PM
does android phone charge usb
